Can I apply surface traction in ANSYS Structure? |
October 5, 2020, 22:08 |
THA SEANGHAI
Rep Power: 5 |
Hello! I want to apply surface traction between Concrete and rebar in ANSYS Structure, Is it possible?
Thank you in advanced! I will appreciate all your advices and guides! |
How does ANSYS FLUENT model the surface tension in the Eulerian (multi-fluid) model? | mohamedh | Fluent Multiphase | 8 | January 3, 2024 09:07 |
[snappyHexMesh] Surface triangulation using snappyHexMesh | shaileshbg | OpenFOAM Meshing & Mesh Conversion | 4 | October 17, 2019 04:42 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Thermal modelling of a ship structure using ANSYS | chetanladha | ANSYS | 2 | April 14, 2011 15:25 |
