ICEM CFD Swept surface does not follow curves
Like Tree2Likes
  • 1 Post By bluebase
Old   November 15, 2020, 07:57
Question ICEM CFD Swept surface does not follow curves
MDN
M
MDN is on a distinguished road
Dear all,
I am attempting to extend the edge of a structure by using the 'sweep surface' tool and selecting the curves of the edges. However, I find the swept surface is not always attached to the original surface and doesn't always follow the curves perfectly. Is there a way to fix this?
Thank you very much.
MDN is offline   Reply With Quote
Old   December 2, 2020, 13:37
Smile Thank you
MDN
M
Thanks so much for your offer to help. I was using ICEM CFD and I found that although there were gaps in the model, after meshing in ICEM CFD there were no visible gaps in the mesh. Does this suggest that I don't need to worry about the gaps in the model?
Thanks a lot.
Old   December 4, 2020, 14:20
Sebastian Engel
bluebase will become famous soon enough
Hi MDN,
the graphical view is only a representation of the actual model. The graphics are triangulated and only resolves geometries until a given limit. You can decrease the triangulation tolerance to resolve finer structures at the cost of more workload on your graphics card.
Have a look into the options in the general tab if i remember correctly, there you should find triangulation tolerance.
If this does not work, try decreasing the topology tolerance, i might mixed those two quantites up, and cant check my suggestion.
Somewhat off-topic: This one is a nice read for more abstract perspective: https://blog.pointwise.com/2017/11/2...ry-is-inexact/
In contrast to CAD, ICEM (or most mesh generators) needs mathematically correctly intersected geometries in order to determine what's inside and outside.
Best,
Sebastian
MDN likes this.
bluebase is offline   Reply With Quote
Old   December 6, 2020, 06:27
MDN
M
Hi Sebastian,
Thank you very much for your explanation. I found the link very helpful too and I now understand why the gap exists!
Thanks again!
Best regards,
M
icem, icem cfd, sweep
Just points and no curves in ICEM CFD import xjotek ANSYS 0 November 16, 2017 16:25
[ICEM] Curves deformed/cut when concatenating in ICEM CFD CFDvasu11 ANSYS Meshing & Geometry 0 September 11, 2017 08:59
[ICEM] Surface does not follow curves, ICEM yonpanman ANSYS Meshing & Geometry 1 January 6, 2017 05:29
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Selecting multiple surface in ICEM CFD 4 CFX Ahmed CFX 4 March 15, 2004 10:06
