Flow modeling in 2D geometry as helical coil. |
January 6, 2021, 20:25 |
Hello Sir/Ma'am,
I'm trying to setup helical coil heat exchanger using 2D geometry. Now if one takes cross-section of 3D helical coil, then the person should see bunch of circles aligned next to each other in form of array. Sure, its not possible to setup helical flow in this 2D section because all 3 dimensions play critical role. The flow moves X,Y,Z directions. Now, correct me if I'm wrong but if I put the periodic boundary conditions for each of these circles and periodicity setup only for velocity variable, will it work? The attached geometry shall provide 'some-what' idea that I'm talking about |
January 7, 2021, 10:32 |
Gert-Jan
Rep Power: 27 |
Maybe the approach as described in the PhD thesis of Jasper Kelder from The Eindhoven University of Technology might help:
https://research.tue.nl/en/publicati...al-sterilisers |
January 7, 2021, 13:16 |
Erik
Rep Power: 23 |
I would not recommend proceeding in that 2D way.
Even if it ends up "working", it will take a ton of time and effort to set up and get it to solve, plus the physics will be wrong for multiple reasons I would definitely just Model this in 3D. |
January 7, 2021, 15:43 |
#4 | |
January 7, 2021, 16:10 |
Gert-Jan
Rep Power: 27 |
Indeed, this thesis is all about 3D modelling, but it shows a nice simplification of a helical tube to a straight tube, which is easier to model. So if you want to model what is happening inside the tubes, this could be a valuable approach, even with a small computer, which I suspect you have, since you try to simplify things in a way that is useless as Evelica already mentioned.
Treating a heat exchanger with a helical tube in the way you want to, would not lead to meaning full results since you ignore the dean vortices that help the heat transfer. If you are interested in what is happening outside the helical coil. then simply ignore these and model them as wall with a Neumann-Dirichlet boundary condition with temperature at infinitiy and a heat transfer coefficient. |
Display Modes | |
Modeling the gas flow through the packed bed of DEM particles | Legat | STAR-CCM+ | 6 | January 17, 2024 09:58 |
Simulate particle/liquid flow in a converging geometry with MPPICFoam | minzhang | OpenFOAM Running, Solving & CFD | 4 | August 2, 2019 18:35 |
actual flow rate not match the designed flow rate in ventilation modeling | minecraftgp | OpenFOAM Running, Solving & CFD | 2 | November 18, 2018 13:37 |
Initialize flow from different geometry | B.Axel | FLUENT | 2 | January 24, 2018 14:15 |
Problem with Periodic Boundary for helical coil | nilhas | FLUENT | 0 | January 2, 2013 02:26 |
