create line/Rake in center of Helical coil
Old   February 5, 2021, 13:56
Default create line/Rake in center of Helical coil
Ash Kotwal
Ash Kot is on a distinguished road
Hello All,
Anyone know how to create line or rake across center of helical coil to setup from inlet to outlet in easy way?
One way I can think of it is:
1. Know the (x,y,z) co-ordinates of each point that existing at axis of the coil
2. use those co-ordinates data while create rake points in FLUENT
I believe the procedure that I describe is tedious and lengthy, thus if anyone know the easier way, that'll be awesome?
Ash Kot is offline   Reply With Quote
fluent, helical pipe, line plot, rake points
Flow modeling in 2D geometry as helical coil. Ash Kot ANSYS 4 January 7, 2021 15:10
Tutorial for Boiling flow in helical coil steam generator umararshad91 Fluent Multiphase 6 August 2, 2016 04:15
[Workbench] How to create Rigid links using Center of gravity and Moments of Interia in Ansys WB? bruce321 ANSYS Meshing & Geometry 0 December 31, 2014 19:03
How to create a 2d model of tuble with a center hole huhaijun Fluent Multiphase 0 November 19, 2014 17:29
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 15:22
