Rep Power: 7 ![]() |
Hello every one,
I am trying to create temperature or velocity contours on a curved STL file that I import into ansys post as STL with ASCII format by inserting it as a "User Surface" Although I import and visualize the STL file in ANSYS Post, I can not use the user surface to create contours. Ansys Post can create a legend for the contour that I want but it does not show anything else on the screen. Any ideas are appreciated. |
#2 | |
The STL file should match in dimension only the Domain that you want to post process on. Then under the tab in user surface, you should change constant to variable and select the variable you want. cheers |
Bineet Mehra
Rep Power: 13 ![]() |
hi thanks .
i have almost same issue. for a pipe flow, it shows almost 0 velocity on the stl i imported . thanks in advance for your help ![]() |
Display Modes | |
Blender: generate stl files | student666 | OpenFOAM Pre-Processing | 0 | June 6, 2017 02:45 |
Post-processing star ccm+ results in Ansys CFD Post | sidharath | STAR-CCM+ | 4 | April 10, 2017 11:49 |
OpenFOAm solver, ANSYS post processing | achinta | OpenFOAM | 3 | May 13, 2010 02:54 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Converting ANSYS CFX files to Fluent files | Martin S. Rasmussen | FLUENT | 3 | January 30, 2007 15:08 |
