UDF Species of each phase
I am writting a UDF code to simulate chemical reaction between phases. However, I can not found information (macro or routine) about to select a specific specie of a phase. For example: Species1(phase 1) + Species1(phase 2) ==> Species2(phase 1) How can I use data specifically from Specie1(phase2) in a UDF?? Thanks. |
Domain *domain; |
Does it works with Eulerian multiphase model? and if it is, The code is the same? |
I want to clarify that this is not a whole code. This is just a procedure to access the mass fraction of specie in a phase. By recalling the phase thread and using Y_CI
The answer to your question is yes, it should work with Euler-Euler model |
