Using Fluent in 2D
Old   September 4, 2021, 12:50
Default Using Fluent in 2D
cfdworkstation is on a distinguished road
I learned Fluent in 3D and am now attempting to model a rocket nozzle in 2D, I have made a single surface CAD in SpaceClaim but do not know how to mesh it in Fluent. Opening Meshing in Fluent only gives the option of 3D. Any help would be appreciated.
cfdworkstation is offline   Reply With Quote
Old   September 4, 2021, 19:42
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
If you set up workbench before, you have to change your analysis type 3D to 2D in properties section. I dont know where the section exactly but there is some settings about analysis type. You have to find it
Guvennergiz is offline   Reply With Quote
Old   September 22, 2021, 02:45
Svetlana Tkachenko
Светлана is on a distinguished road
Agreed with you Fluent Meshing appears to only have 3D option. Attached screenshot. Suggest to do it in 3D with one element thickness across the third dimension.
Светлана is offline   Reply With Quote
Old   February 19, 2022, 16:58
Void_CFD-user
Indra is on a distinguished road
Fluent meshing is only for 3D application. You can add some thickness and generate a 2.5D mesh in fluent though.
Indra is offline   Reply With Quote
Old   October 19, 2022, 07:14
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
Also Fluent (without Meshing) in WB has only 3D. You have to launch it standalone.
Mazze[ITA] is offline   Reply With Quote
Old   October 20, 2022, 04:18
MANU P ANAND
manupanand is on a distinguished road
It is because you created the mesh in 3D by default. you have to save mesh in 2D, to get 2D solver option. Did you mesh with Ansys default mesh module or ICEM, try to save as 2 D mesh. You can save as 2 D mesh in ICEM. by default you created 3 coordinate node points.
manupanand is offline   Reply With Quote
CFX vs. FLUENT turbo CFX 4 April 13, 2021 09:08
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
