Zones selected for stitch are not in the same object. |
Svetlana Tkachenko
Rep Power: 15 ![]() |
Imported CAD of a solid plate between two fluid domains (they are not completely flat, it is a heat exchanger). They are touching. Created geometry in ansys spaceclaim. Started meshing in fluent meshing. Fluent meshing gives the following error: Error: Zones selected for stitch are not in the same object. Error Object: #f How can I work around this? Svetlana |
Trupen
Rep Power: 0 ![]() |
Just in case if somebody gets the same error and happen to come around to this post - All your "solids" or "solid+fluid" should be under the same part. To do this, go to designmodeller, select all the solids, than right-click and "Form new part". This would solve the problem with this error in Fluent meshing.
Display Modes | |
interFoam and scalarTransport function object with fvOptions sources | fusij | OpenFOAM Running, Solving & CFD | 4 | April 18, 2022 07:12 |
fluent error gui-domain-label: no domain selected Error Object: 1038410352 | Fari87 | FLUENT | 6 | January 31, 2021 23:57 |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 14:22 |
[TUTORIAL] Implementing porous zones to PisoFOAM | ssss | OpenFOAM Programming & Development | 6 | July 31, 2018 14:23 |
values take by probes function object | zfaraday | OpenFOAM Post-Processing | 0 | July 7, 2014 11:06 |
