Set New Design Point in WB from Fluent/CFX
Old   November 3, 2021, 03:46
Lightbulb Set New Design Point in WB from Fluent/CFX
Eva Knahl
EvaKn is on a distinguished road
I want to simulate a Heat Transfer Process in Fluent.
In this simulation I have heat transfer from surrounding fluid to a solid body. The Temperature of the body is the whole process constant but its volume rise through the heat transfer.
So I can not use temperature dependent density in material data.
I thought maybe it is possible to set automatically at the end of the calculation a design point in Workbench with the new size of the geometry and material data. Is that possible? (In the end of the calculation it is planned to calculate through expression the new design parameter)
I thought also the option of FSI, but the DP variant sounds easier(faster) in the first place. Because in FSI you also have only the option of temperature dependent Materialdata.
Thanks a lot for your answers.
Best regards,
Eva K.
EvaKn is offline   Reply With Quote
design point, fluent - udf
Non-Positive Volume Cell while Point Set Morphing in Star CCM+ Ranshua STAR-CCM+ 1 May 4, 2022 03:39
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
