Archimedes screw turbine - non-physical results |
June 2, 2022, 19:35 |
Alberto marasi
Hi guys,
My master's thesis project consists in simulating an Archimedes screw turbine using ansys fluent CFD. I imported the geometry from SOLIDWORKS, generated a good quality mesh, and set the fluent. However, the torque generated by the simulation is excessively high, generating non-physical results (power generated by the turbine greater than the hydraulic one). What could be the problem? I used the following settings: Transient simulation VOF implicit formulation (water + air) K-w SST model Mesh motion to simulate machine rotation (known rps) Mass flow inlet (to set the inlet flow) Pressure outlet (to adjust the outlet flow) Second order upwind everywhere Under relaxation factor 0.1 Flow courant number 50 Time step 0.005 sec. Thank you |
Display Modes | |
URGENT! My Archimedes Screw turbine is not turning properly | jassonsee | FLOW-3D | 2 | August 6, 2020 13:14 |
bad heat transfer results with low y+ | me45 | OpenFOAM Running, Solving & CFD | 0 | April 29, 2020 11:56 |
not physical results at the mixing plane interface. | andreaRocca | OpenFOAM Running, Solving & CFD | 0 | November 4, 2019 11:07 |
Ducted wind turbine (BC for the shroud) | Pepita | CFX | 4 | June 29, 2013 07:09 |
wind turbine simulation, Ansys Post results question | Laions | CFX | 7 | September 20, 2011 05:13 |
