Heat Transfer Coefficient for Heat Flux = 0 W/m^2
Old   June 14, 2022, 07:37
Default Heat Transfer Coefficient for Heat Flux = 0 W/m^2
CellZone is on a distinguished road
I applied for a high mach flow simulation over a plate the following boundary conditions for the plate:
Thermal: Heat Flux -- > Heat Flux 0 W/m^2 ; Wall Thickness = 0 m^2 ; Heat Generation Rate 0 W/m3
When I export the srf file for this surface, I get temperatures as well as heat transfer coefficients.
I am wondering, why I get heat transfer coefficients. According to the formula dot q = htc * A * (T_wall - T_Fluid)
So dot q is according to my settings 0 W/m^2.
So either the htc or T_Wall must be zero. But for both I get values. Why?
Does Fluent use for the wall temperature the stagnation temperature?
Thank you for your help!!
Best regards
CellZone
CellZone is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
How To Calculate Average Heat Transfer Coefficient in CFD-Post? Shomaz ul Haq CFX 16 November 24, 2019 18:57
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 13:32
High values of heat transfer coefficient for laminar flow in pipe Allankey CFX 2 May 28, 2014 12:44
