export node temperature using udf
Old   June 19, 2022, 08:42
Default export node temperature using udf
Henry
jscsgh is on a distinguished road
Hiya, I am modelling a transient case with two phases, and I would like to know the temperature development of the nodes in a certain thread. I used udf to export the coordinates of the wanted nodes successfully. However, I had some problems when I tried to export the temperature. I defined the field variable name using the following lines:
char *what = "temperature";
Node_Function_Values(d, what);
And I tried to obtain the temperature value using NODE_VALUE(v). But it reports as follows when I tried to print the temperature value.
Error: floating point exception
Error Object: #f
The fl process could not be started.
What is the possible reason which would cause this?
Is it possible that the field variable name that I am using is not right, since it is a multiphase case. How can I know the list of field variable names that I can use in the function Node_Function_Values(d, what); for a multiphase case.
Many thanks for your time.
jscsgh is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 00:17
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 21:48
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 09:46
