how do i can fix?
Old   June 23, 2022, 21:41
Default how do i can fix?
HOJUN YU
hobing is on a distinguished road
hi all.
i'm using ansys 19.0 in Cent OS 7.3
When I try to run FLUENT,
there is no further progress on the following screen.
No matter how long I wait, it does not proceed on that screen.
There is no error log,
and without turning on the GUI with the
"fluent 3ddp -t64 -d" command in the terminal, TUI works normally.
How can I solve this problem?
Additionally
There is content like the picture.
help.. thank you
hobing is offline   Reply With Quote
Old   July 5, 2022, 07:28
geth03 is on a distinguished road
i recently installed ansys on cent os 7.
after installation i had to install other stuff to run the GUI, i had that problem too. i found the solution somewhere in this forum i think.
geth03 is offline   Reply With Quote
Old   July 6, 2022, 06:57
HOJUN YU
thank you!
'yum update' After the update, it runs normally!
But I still don't know what the problem was.
Additionally, if you update 'yum update', the version may not match with ANSYS,
so I don't think you should update the kernel!
hack - using porous region to fix local instability ufocfd OpenFOAM Running, Solving & CFD 0 August 14, 2021 09:49
Can’t fix pierced faces cgswjs Siemens 0 July 1, 2019 20:04
Fix Reynolds Number in a periodic flow chusma OpenFOAM Pre-Processing 10 June 12, 2019 02:08
Intel security flaw - windows update fix 40% slowdown fonograph Hardware 13 April 4, 2018 23:53
Inventor - Bug in Geometry: How to Fix? StarCFD Main CFD Forum 0 February 9, 2015 20:28
