Plot resulting moment for Beam188 element
Old   August 3, 2022, 12:57
Default Plot resulting moment for Beam188 element
Daniele.96 is on a distinguished road
i'm using Ansys Mechanical APDL to study the mechanical behavior of a cellular structure. To model the elements that compose the structure i've used the element "Beam188" for a first analysis. I have seen in Ansys help that i can plot bendying moment in y direction and bendying moment in z direction separatly (where y and z are referred to beam local coordinate system) and the same thing is for shear stress through the command "SMISC". But i want to plot (or calcolate) the vector sum M_y+M_z to see immeditly where the beam is more stressed by bending, thing that is difficult plotting bending moments separatly.
Thanks for help.
Daniele.96 is offline   Reply With Quote
ansys, apdl, beam, mechanical, mechanical apdl
[Gmsh] gmshToFoam unhandled element flowris OpenFOAM Meshing & Mesh Conversion 4 February 20, 2023 17:50
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:56
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
