Zones selected for stitch are not in the same object. |
October 24, 2021, 18:02 |
Svetlana Tkachenko
Rep Power: 14 |
Imported CAD of a solid plate between two fluid domains (they are not completely flat, it is a heat exchanger). They are touching. Created geometry in ansys spaceclaim. Started meshing in fluent meshing. Fluent meshing gives the following error: Error: Zones selected for stitch are not in the same object. Error Object: #f How can I work around this? Svetlana |
August 24, 2022, 13:42 |
Trupen
Just in case if somebody gets the same error and happen to come around to this post - All your "solids" or "solid+fluid" should be under the same part. To do this, go to designmodeller, select all the solids, than right-click and "Form new part". This would solve the problem with this error in Fluent meshing.
Display Modes | |
interFoam and scalarTransport function object with fvOptions sources | fusij | OpenFOAM Running, Solving & CFD | 4 | April 18, 2022 08:12 |
fluent error gui-domain-label: no domain selected Error Object: 1038410352 | Fari87 | FLUENT | 6 | February 1, 2021 00:57 |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 15:22 |
[TUTORIAL] Implementing porous zones to PisoFOAM | ssss | OpenFOAM Programming & Development | 6 | July 31, 2018 15:23 |
values take by probes function object | zfaraday | OpenFOAM Post-Processing | 0 | July 7, 2014 12:06 |
