WSGG radiation model
Like Tree1Likes
  • 1 Post By alainislas
Old   August 2, 2022, 05:29
Default WSGG radiation model
Kuljeet Singh
Kuljeet is on a distinguished road
Hi, can I compute weighing factor and k value for each gray gas which ANSYS is simulating with in WSGG radiation model.
-K
Kuljeet is offline   Reply With Quote
Old   August 2, 2022, 11:05
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
In Ansys Fluent, the default WSGGM coefficients are the ones shown in Smith et al. 1982 (https://doi.org/10.1115/1.3245174). You can use temperature to create a custom field to plot/show the weighting factors and the absorption coeffiients for each gray gas.
alainislas is offline   Reply With Quote
Old   August 6, 2022, 04:33
Kuljeet Singh
thank you for the reply. I have read that paper. if possible can you elaborate a little about using custom fields.
-K
Old   August 8, 2022, 13:04
alainislas's Avatar
Alain Islas
In the WSGGM model, the emissiity weighting factors \alpha_{\varepsilon} are expressed as a polynomial function of temperature of order N_{g} , i.e.
\alpha_{\varepsilon,i}(T)=\sum_{j=0}^{N_{g}}b_{\varepsilon,i,j}T^{j}
where N_{g} is the number of gray gases (3 in the work of Smith et al. 1982). For example in Table 1, for a mixture with MR = 2.0 you have
\alpha_{\varepsilon,1}(T)=6.508\times 10^{1} - 5.551\times 10^{4}\cdot T + 3.029\times 10^{7}\cdot T^{2} - 5.353\times 10^{11}\cdot T^{3}
\alpha_{\varepsilon,2}(T)=-0.2504\times 10^{1} + 6.112\times 10^{4}\cdot T - 3.882\times 10^{7}\cdot T^{2} + 6.529\times 10^{11}\cdot T^{3}
\alpha_{\varepsilon,3}(T)=2.718\times 10^{1} - 3.118\times 10^{4}\cdot T + 1.221\times 10^{7}\cdot T^{2} - 1.612\times 10^{11}\cdot T^{3}
I believe if you read Fluent User Manual you can easily type above expressions in the dialog box of the custom field expression, create such fields and later postprocess them (contours, lines, probes, etc...)
Then, what else you want to plot? 1) the absorption coefficients k_{i} ? or 2) the i-th emissivities \varepsilon_{i} ?
If its the first case, they are already shown in Table 1 (2nd column). If its the second, you can use Eq. (1) to create corresponding field expressions for each \varepsilon_{i}
shamcross likes this.
Old   September 28, 2022, 06:37
jannothi
jannothi is on a distinguished road
jannothi is offline   Reply With Quote
Radiation model fvDoM get huge radiative heat flux fxzf OpenFOAM Running, Solving & CFD 0 April 23, 2018 10:28
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 10:29
Wsgg radiation model deoshh FLUENT 2 July 17, 2014 02:05
problem in glass radiation model (DO model) wunan805 FLUENT 0 October 10, 2012 05:06
Help: Radiation model MANOJKUMAR FLUENT 4 November 24, 2005 02:45
