August 14, 2023, 07:56 |
Transient Thermal / Fluent: Film Coefficient
Sunghyun Woo
Rep Power: 2 |
I want to run Heat transfer simulation in Fluent and Transient Thermal. Model Explanation : Auto battery is 25 degree, Air Temperature is 50 °C. Air heat the battery for 24 hours and check the temperature change each component. Fluent: I can define just the temperature of Air of the device (withouth fored air circulation, just ambitious air) then I can get the data of Temperature. ## Ambient Air Temp : 50 °C Other battery components :25°C Transient Thermal: I should define the value of Film coefficient, which I as a convection coefficient understood. ## Ambient Air Temp: 50°C, but Film coefficient missed. Other battery components : 25°C If I want to run both Simualtion tools with the same condition, which value should I give in Transient Thermal? Thank you for your Answer!! |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Transient thermal deviating results | RichardL | ANSYS | 0 | June 6, 2018 10:28 |
Glass mould analysis (transient thermal and Fluent) | oozcan | CFD Freelancers | 5 | May 20, 2016 00:26 |
Glass mould analysis (transient thermal and Fluent) | oozcan | ANSYS | 0 | May 10, 2016 07:42 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
