March 23, 2021, 12:11 |
Autodyn doesn't utilize my CPU properly
The_Immortal
Rep Power: 9 |
Hello!
I start Autodyn from Workbench and then run the proccess. The problem is Autodyn utilizes my CPU (i5-4690K) only on 30% and use 1GB RAM of 32 GB RAM. How can I solve this problem? Thank you! |
December 5, 2022, 11:39 |
Erik
Rep Power: 23 |
The solver will only use as many cores as you set it to use, or your license supports. I'm not familiar with AutoDYN, but it sounds like it is running in serial mode (1 core) out of your 4 cores. looking at the AUTODYN parallel processing tutorial, it looks like serial calculation is default.
https://vdocument.in/ansys-autodyn-p...l.html?page=11 The problem also takes up only so much room, they won't fill up all your RAM if the problem is small and fits in only 1 GB. |
autodyn, cpu load |
compiler does not utilize all CPU? | AnhDL | Main CFD Forum | 0 | May 18, 2020 22:20 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 05:26 |
How to fully utilize my cpu | Effendi Ali | FLUENT | 14 | February 17, 2004 20:11 |
