Multi Element Airfoil
Old   December 3, 2022, 18:09
Default Multi Element Airfoil
Lalo Star
Firzen822 is on a distinguished road
I am conducting my first simulation on a multi element airfoil on Ansys Fluent, I would like to know if I am doing good or not, because I am unsure of my progress.
I also need to do this study for a specific Reynolds number, any help with that/
Thank you, any insight on this would be very helpful.
Firzen822 is offline   Reply With Quote
Old   January 5, 2023, 07:31
Chrowale
mluckyw is on a distinguished road
Does the simulation converges numerically? and if you have the experimental data, please do compare it. its the most foolproof way to validate the result.
Could you increase the number of contour, because in your picture the deviation is very large from one color to the next and could be wrongly interpreted.
Assuming the contour would not changed after increasing in contour number, I think there's a mistake when you set the inlet pressure. CMIIMW
mluckyw is offline   Reply With Quote
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
Identifying Markers in a CGNS Mesh tjim SU2 3 October 12, 2018 01:21
multi element forceCoeffs s.m OpenFOAM Running, Solving & CFD 0 May 6, 2013 05:16
[GAMBIT] Multi Element Airfoil Meshing wanfuhh ANSYS Meshing & Geometry 1 May 6, 2013 02:45
