Ansys 2019R3 workbench failes to load on Rhel 8.6
Old   February 21, 2023, 17:15
Question Ansys 2019R3 workbench failes to load on Rhel 8.6
Sultan Islam
EternalSeekerX is on a distinguished road
Hello everyone,
So we are in need to ansys 2019 as well for the computers we run on. Ansys 2020 and 2021 run fine on Rhel 8.6. We understand that 19.3 does not support Rhel 8.6, however we were able to get the required 7.6 libraries and install them to another directory and then add them to LD_LIBRARY_PATH. Now most things in Ansys work except for workbench mechanical and workbench mesh. Workbench mechanical freezes during geometry attach and these error pop in terminal:
Generating profiling data for startup process.
Process dic is being accessed
Layout: <SystemBlock Schematic> <block for <new system <SystemId :SYS:0>>>
Creating through CreationInfo: mode CreateSystem, position Default from (none)
Ansys.Meshing.Core.DataModel.MeshProperties.GetSaveMeshFileInSeparateFilePreferenceValue : Warning AL2 : Waiting for a command while holding a lock, this has the potential to deadlock.
Throwing failure exception from wait: No Component with name or basename 'Model' was found in system 'SYS'.
Layout: <SystemBlock Schematic> <SystemBlock SYS>
Container Geometry outputs generated, regen time from 0 -> 1758
Error BadValue (integer parameter out of range for operation) on display :0.0
    Object Address 2
    sequence 157
    error code 2
    request code X_SetFontPath (51)
    minor code 0
mwrpcss:2153:RPCSS port number 135 is overrided by 39571
/rhce/Ansys/Ansys2019R3/ansys_inc/v195/aisol/../aisol/dll/linx64/libcommandbars.so/rhce/Ansys/Ansys2019R3/ansys_inc/v195/aisol/../aisol/dll/linx64/libdockingpane.soError BadValue (integer parameter out of range for operation) on display :0.0
    Object Address 2
    sequence 158
    error code 2
    minor code 0
/rhce/Ansys/Ansys2019R3/ansys_inc/v195/aisol/../aisol/dll/linx64/libcommandbars.so/rhce/Ansys/Ansys2019R3/ansys_inc/v195/aisol/../aisol/dll/linx64/libcommandbars.so/rhce/Ansys/Ansys2019R3/ansys_inc/v195/aisol/../aisol/dll/linx64/libcommandbars.so/rhce/Ansys/Ansys2019R3/ansys_inc/v195/aisol/../aisol/dll/linx64/libcommandbars.soProcess dic is being accessed
Error BadWindow (invalid Window parameter) on display :0.0
    Object Address 5096615
    sequence 8163
    error code 3
    request code X_GetWindowAttributes (3)
    minor code 0
Throwing failure exception from wait: Error while waiting for Meshing initialization to complete. Tcp transport error.
UIManager.InvokeOperationCore (CommandFailedException)
Ansys.Core.Commands.CommandFailedException: Error while waiting for Meshing initialization to complete. Tcp transport error. ---> System.InvalidOperationException: Error while waiting for Meshing initialization to complete. Tcp transport error.
  at Ansys.Addins.Infrastructure.Remoting.RemotingApiHelper.FatalApiMethodInvalidOperationException (System.String message, Ansys.Addins.Infrastructure.Remoting.RemotingApiMethod callback) [0x00070] in <d26f4e15534a4a77bbf277c34ea25406>:0
  at Ansys.Meshing.Core.ISimulationHelperWrapper.WaitForRemotingInitialization () [0x00015] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.Core.Commands.MeshingProcessStarter.SetupSimulationProcessConnection (Ans.IPC.Remoting.Server.ServerToClientConnection addinToApplicationConnection, System.Boolean connectEvents) [0x00044] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.Core.Commands.MeshingProcessStarter.Start (System.Boolean connectEvents) [0x0009c] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.Core.Commands.MeshingProcessStarter.Start () [0x00000] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.Core.ExternalProcessHandlers.StartSimulation (Ansys.Core.Commands.IFullContext context, System.Boolean bInBatch, Ansys.Core.DataModel.ProjectSystem.DataContainerReference modelContainer, Ansys.Core.DataModel.DataReference connectionRef, System.Boolean checkRequiredLicenseCapabilities) [0x00072] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.Core.ExternalProcessHandlers.StartSimulationAndOpenDatabase (Ansys.Core.Commands.IFullContext context, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.Boolean bIsBatchMode, System.Boolean bRequireLicense) [0x00091] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.Core.Commands.StartMeshingEditor.ExecuteCommand (Ansys.Core.Commands.IFullContext context) [0x00015] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0000e] in <d26f4e15534a4a77bbf277c34ea25406>:0
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00075] in <1d117354ba7d4a4d8d90fd0122d9d025>:0
   --- End of inner exception stack trace ---
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in <1d117354ba7d4a4d8d90fd0122d9d025>:0
  at Ansys.Core.Commands.CommandAsyncResult.Wait (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000ae] in <1d117354ba7d4a4d8d90fd0122d9d025>:0
  at Ansys.Core.Commands.CommandAsyncResult.Wait () [0x00000] in <1d117354ba7d4a4d8d90fd0122d9d025>:0
  at Ansys.Meshing.Core.Commands.StartMeshingEditor.InvokeAndWait (Ansys.Core.Commands.IProtectedContext context, Ansys.Core.DataModel.ProjectSystem.DataContainerReference ModelContainer, System.Boolean IsBatchMode, System.Boolean RequireLicense) [0x00033] in <1bf5f286935b4c0ea9ac01956e1c405a>:0
  at Ansys.Meshing.GUI.EditModel.Invoke (Ansys.UI.GuiOperationContext context) [0x000d9] in <10271e97d76d472bbf297f35da6c4976>:0
  at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00007] in <2bdab8585f3645bcb7d58c4ff69a45bf>:0
  at Ansys.UI.UIManager+<InvokeOperation>c__AnonStorey0.<>m__0 () [0x00037] in <2bdab8585f3645bcb7d58c4ff69a45bf>:0
  at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001ea] in <2bdab8585f3645bcb7d58c4ff69a45bf>:0
*** making exception trace ***
--- Ansys.Core.Commands.CommandFailedException: Error while waiting for Meshing initialization to complete. Tcp transport error.
CommandName: Meshing.StartMeshingEditor(ModelContainer="Mesh")
[Error]: Error while waiting for Meshing initialization to complete. Tcp transport error.
TemplateToolboxModel: waiting for previous background update
TemplateToolboxModel: updating templates
TemplateToolboxModel: updated templates, requesting refresh
TemplateToolboxModel: refresh requested
[Progress]:
Shutting down toolbox models
TemplateToolboxModel: cancelling any background template updates
TemplateToolboxModel: background template updates cancelled
Unloading Ansys.Help.HelpManagerAddin
Unloading Ansys.Help.HelpManagerUIAddin
Unloading Ansys.PythonScriptingEngine.Addin
Unloading Ansys.JobManager.Addin
Unloading Ansys.ParameterManager.ParameterManagerAddin
Unloading Ansys.ProjectSchematic.ProjectSchematicAddin
Unloading Ans.TabularData.TabularDataAddin
Unloading Ansys.ProjectReporting.Addin
Unloading Ansys.Graphics.GraphicsAddin
Unloading Ansys.Units.Commands.Addin
Unloading Ansys.Units.GUI.Addin
Unloading Ansys.Units.DataModel.Addin
Unloading Ansys.TestingAddin.Base.Addin
Unloading Ansys.WBDBMigrate.Addin
Unloading Ansys.WorkbenchServer.WorkbenchServerAddin
Unloading Ansys.JobMgrAdapter.JobMgrAdapterAddin
Unloading Ans.SceneGraphChart.SceneGraphAddin
Unloading ACP.Addin
Unloading Ansys.ACT.WorkBench.Addin
Unloading Ansys.ANSYS.Core.Addin
Unloading Ansys.ANSYS.GUI.Addin
Unloading Ansys.CFX.Foundation.FoundationAddin
Unloading Ansys.CFX.CFDPost.CFDPostAddin
Unloading Ansys.CFX.CFXCore.CFXCoreAddin
Unloading Ansys.DesignXplorer.Commands.Addin
Unloading Ansys.DesignXplorer.GUI.Addin
Unloading Ansys.Rom.Addin
Unloading Ansys.Dpdb.DpdbAddin
Unloading Ansys.EKM.Batch.Addin
Unloading Ansys.EKM.Gui.Addin
Unloading Ansys.ExternalConnectionAddin.Addin
Unloading Ansys.ExternalLoad.Core.Addin
Ansys.ExternalLoad.Core: Unload Started
Unloading Ansys.ExternalLoad.GUI.Addin
Ansys.ExternalLoad.GUI: Unload Started
Ansys.ExternalLoad.GUI: Unload Finished
Unloading Ansys.Fluent.Addin
Ansys.Fluent: Unload Started
Ansys.Fluent: Unload Finished
Unloading Ansys.Fluent.Gui.Addin
Unloading Ansys.Forte.Core.Addin
Unloading Ansys.ICEMCFD.Addin
Unloading Ansys.ICEngine.Addin
Unloading Ansys.IcePak.Core.Addin
Ansys.IcePak.Core: Unload Started
Ansys.IcePak.Core: Unload Finished
Unloading Ansys.IcePak.GUI.Addin
Ansys.IcePak.GUI: Unload Started
Ansys.IcePak.GUI: Unload Finished
Unloading Ansys.Simulation.Core.Addin
Unloading Ansys.Simulation.GUI.Addin
Unloading Ansys.Meshing.Core.Addin
Unloading Ansys.Meshing.GUI.Addin
Unloading Ansys.EngineeringData.Commands.Addin
Unloading Ansys.EngineeringData.Gui.Addin
Unloading Ansys.EngineeringData.DataModel.Addin
Unloading Ansys.EngineeringData.RESTfulService.Addin
Unloading Ansys.Minerva.Core.Addin
Unloading Ansys.MSExcel.Core.Addin
Unloading Ansys.MSExcel.GUI.Addin
Unloading Ansys.MultiphysicsCoupling.Core.Addin
Unloading Ansys.MultiphysicsCoupling.GUI.Addin
Ans.MultiphysicsCoupling.GUI: Unload Started
Ans.MultiphysicsCoupling.GUI: Unload Finished
Unloading Ansys.Polyflow.Addin
Ansys.Polyflow: Unload Started
Ansys.Polyflow: Unload Finished
Unloading Ansys.VistaTF.DataModel.DataModelAddin
Unloading Ansys.VistaTF.Gui.GuiAddin
Unloading Ansys.TurboSystem.TSBase.TSBaseAddin
Unloading Ansys.TurboSystem.Gui.GuiAddin
Unloading Ansys.DesignModeler.Core.Addin
Unloading Ansys.DesignModeler.GUI.Addin
Unloading Ansys.FEModeler.Core.Addin
FEM: Ansys.FEModeler.Core: Unload Started
FEM: Ansys.FEModeler.Core: Unload Finished
Unloading Ansys.FEModeler.GUI.Addin
FEM: Ansys.FEModeler.GUI: Unload Started
FEM: Ansys.FEModeler.GUI: Unload Finished
Calling ExitLicensing
    Object Address 2
    sequence 159
    error code 2
    minor code 0
However, sometimes it will load, but then freeze when we run mesh, it will show a green checkmark around mesh in the tree, but become unresponsive, the mesher progress bar doesn't even show up either. We are wondering why everything but workbench mesher works? Is there additional pre-requisite packages we are missing?
Thanks for any help!
EternalSeekerX is offline   Reply With Quote
Old   February 21, 2023, 17:24
Default Additiona Info
Sultan Islam
Originally Posted by EternalSeekerX View Post
-snip-
Here is the terminal output when we were able to run workbench mechanical, but then fails to run mesh:
Application Startup: 12.915 s, 64170 kb delta, 64170 kb total
Container Engineering Data outputs generated, regen time from 0 -> 2459
Container Engineering Data outputs generated, regen time from 2456 -> 2459
Container Engineering Data outputs generated, regen time from 2457 -> 2459
Container Engineering Data outputs generated, regen time from 2458 -> 2459
Current version of the SimulationModelGeneratedMeshDataObject is 2
Current version of the SimulationModelGeneratedMeshDataObject is 1
Current version of the SimulationGeneratedSolidMesh is 1
Ansys.Simulation.Core.DataModel.SimulationMeshProperties.GetSaveMeshFileInSeparateFilePreferenceValue : Warning AL2 : Waiting for a command while holding a lock, this has the potential to deadlock.
Throwing failure exception from wait: No system is associated with the component Model
Container Geometry outputs generated, regen time from 0 -> 2549
It seems like ansys mesher is the one that's failing to run
Ansys Workbench 17.1 not showing up..? AlexRonto ANSYS 3 May 5, 2022 03:28
ANSYS Workbench is hanging or taking too much time opening CFX tab after crashing Mfaizan CFX 1 April 15, 2016 02:46
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 17:07
2way FSI with Ansys workbench lingdeer ANSYS 3 May 9, 2013 03:48
Export Heat Flux CFX -> ANSYS Workbench Freeman CFX 2 April 11, 2010 08:24
