System Coupling Help
Old   March 8, 2023, 12:12
Default System Coupling Help
Nouzil
inouzil is on a distinguished road
I want to setup a system coupling interface with temperature data transfer between transient thermal and fluent. A solid body is given a heat flux boundary condition and fluid structure interaction zone is defined. The aim is to transfer temperature on the solid body after each time step to fluent. Fluent will then apply a coolant for the same duration of time. The geometry image is attached. The system coupling setup image is also attached.
When I try to create a data transfer for the fluid structure interaction region, it does not allow me to define temperature as input to the wall in fluent module. The wall does not take any inputs. Any help in this is greatly appreciated.
Thank you
inouzil is offline   Reply With Quote
Heat-Fluid System Coupling arkaragian ANSYS 0 October 13, 2019 10:41
CFX System Coupling - How to rotate an Outlet Boundary Condition zjuv9021 CFX 1 April 6, 2019 23:36
Time dependent piezoelectric actuation voltage with system coupling for 2 way fsi Francis Hauris ANSYS 0 April 1, 2018 22:23
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 09:12
System coupling problem Sony FLUENT 0 September 17, 2013 20:51
