User defined particle injection areas
Old   April 5, 2012, 03:20
Default User defined particle injection areas
@p N
yvonne is on a distinguished road
I want to carry out particle tracking in CFX 13. I need to inject particles only in certain regions of the domain where pressure drops below a threshold value. I have generated this data and I have it in form of coordinates and I need to use this to define the particle injection region.I tried the same by using the pt_injection.ccl subroutine and pt_injection user function. What is not clear to me is
  • how do I import the user function? I went to Insert--> User function; but in that case I have to specify the arguments, results and their respective units.
  • do I need to edit the Library Path?
  • when I import this ccl, another domain ‘tank’ gets created. Each domain gets an additional parameter ‘region’ suffixed under it.
  • Is this where I have to specify the file containing coordinates? But I don’t see any such input.
  • Do I have to create the 'share library'?
yvonne is offline   Reply With Quote
Old   March 8, 2023, 17:52
Isar Charmchi
Isar.charmchi is on a distinguished road
Hi, have you find the answer to your question? Can you please share how you did it?
Isar.charmchi is offline   Reply With Quote
cel, cfx, particle tracking, user defined
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Particle injection boundary condition fjalil CFX 8 September 23, 2009 09:40
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
UDF - Derivatives for User Defined Memory Variable Sandilya Garimella FLUENT 0 January 14, 2008 10:39
User defined scalar Tomik FLUENT 0 February 8, 2007 19:23
