Excel file not generated when using excel to post process
Hi all, when I try to analyze data in CHEMKIN via excel to post-process there is no excel file generated, instead I am getting of the feedback below:
Exception thrown during Excel conversion jp.ne.so_net.ga2.no_ji.jcom.IDispatch._create(Nati ve Method) jp.ne.so_net.ga2.no_ji.jcom.IDispatch.create(IDisp atch.java:84) jp.ne.so_net.ga2.no_ji.jcom.IDispatch.<init>(IDisp atch.java:46) jp.ne.so_net.ga2.no_ji.jcom.excel8.ExcelApplicatio n.<init>(ExcelApplication.java:8) com.chemkin.gui.PanelPostProcessUtilities.useExcel JNI(PanelPostProcessUtilities.java:498) com.chemkin.gui.PanelPostProcessUtilities.useExcel (PanelPostProcessUtilities.java:284) com.chemkin.gui.PanelPostProcess$8.actionPerformed (PanelPostProcess.java:1297) javax.swing.AbstractButton.fireActionPerformed(Abs tractButton.java:2022) javax.swing.AbstractButton$Handler.actionPerformed (AbstractButton.java:2346) javax.swing.DefaultButtonModel.fireActionPerformed (DefaultButtonModel.java:402) javax.swing.DefaultButtonModel.setPressed(DefaultB uttonModel.java:259) javax.swing.AbstractButton.doClick(AbstractButton. java:376) javax.swing.AbstractButton.doClick(AbstractButton. java:356) com.chemkin.gui.PanelPostProcess$8.actionPerformed (PanelPostProcess.java:1252) javax.swing.AbstractButton.fireActionPerformed(Abs tractButton.java:2022) javax.swing.AbstractButton$Handler.actionPerformed (AbstractButton.java:2346) javax.swing.DefaultButtonModel.fireActionPerformed (DefaultButtonModel.java:402) javax.swing.DefaultButtonModel.setPressed(DefaultB uttonModel.java:259) javax.swing.plaf.basic.BasicButtonListener.mouseRe leased(BasicButtonListener.java:252) java.awt.Component.processMouseEvent(Component.jav a:6525) javax.swing.JComponent.processMouseEvent(JComponen t.java:3324) java.awt.Component.processEvent(Component.java:629 0) java.awt.Container.processEvent(Container.java:223 4) java.awt.Component.dispatchEventImpl(Component.jav a:4881) java.awt.Container.dispatchEventImpl(Container.jav a:2292) java.awt.Component.dispatchEvent(Component.java:47 03) java.awt.LightweightDispatcher.retargetMouseEvent( Container.java:4898) java.awt.LightweightDispatcher.processMouseEvent(C ontainer.java:4533) java.awt.LightweightDispatcher.dispatchEvent(Conta iner.java:4462) java.awt.Container.dispatchEventImpl(Container.jav a:2278) java.awt.Window.dispatchEventImpl(Window.java:2750 ) java.awt.Component.dispatchEvent(Component.java:47 03) java.awt.EventQueue.dispatchEventImpl(EventQueue.j ava:751) java.awt.EventQueue.access$500(EventQueue.java:97) java.awt.EventQueue$3.run(EventQueue.java:702) java.awt.EventQueue$3.run(EventQueue.java:696) java.security.AccessController.doPrivileged(Native Method) java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:75) java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:86) java.awt.EventQueue$4.run(EventQueue.java:724) java.awt.EventQueue$4.run(EventQueue.java:722) java.security.AccessController.doPrivileged(Native Method) java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:75) java.awt.EventQueue.dispatchEvent(EventQueue.java: 721) java.awt.EventDispatchThread.pumpOneEventForFilter s(EventDispatchThread.java:201) java.awt.EventDispatchThread.pumpEventsForFilter(E ventDispatchThread.java:116) java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:105) java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:101) java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:93) java.awt.EventDispatchThread.run(EventDispatchThre ad.java:82) |
Solution
You need to locate the excel file in your CHEMKIN folder named as: CKSoln_solution_no_1.csv |
