FENSAP ICE icing wind turbine airfoil blade section |
Rep Power: 2 ![]() |
Hi Community,
I am working on a realistic scenario for a section a wind turbine blade with an incoming wind speed and droplets using FENSAP ICE. My configuration looks something like this: My idea is to simulate while the wind turbine is under operation so i need to a add a relative speed to the airfoil considering that the wind flow is coming from the left side. Any suggestion how to recreate this simulation? Thanks in advance |
Display Modes | |
Thrust Force calculation on Wind turbine blade | vd93 | OpenFOAM Post-Processing | 2 | February 6, 2022 22:35 |
Problem with forces and moment calculated for wind turbine blade using simpleFoam | mostafa kamal | OpenFOAM Running, Solving & CFD | 2 | September 21, 2021 17:33 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
wind turbine blade flow simulation | rsskarthikeyan | FLUENT | 0 | May 27, 2015 05:40 |
Wind Turbine Blade rotation | mmd_knr | FLUENT | 1 | August 8, 2012 14:52 |
