Flow with counterflow and porous membrane (Ansys CFX) |
Rep Power: 0 ![]() |
I need help with a project with Ansys CFX where I have a pipe flow in positive x_direction, a porous domain around it and another pipe with a flow in negative x_direction around the porous domain. I want to calculate with water everywhere. For the porous domain, I have information on porosity and permeability. I would like to specify the velocity at the inlet of the inner and outer flow and the ambient pressure at the outlet of the two flows. I have chosen k-Epsilon as the turbulence model. I have already found the 'constant domain physics' setting. It also flows in countercurrent. Now to the problem. Nothing flows through the porous domain and I don't know why. The pressure and velocity are always zero. Maybe someone has an idea and can help me. Thanks for reading. |
Gert-Jan
Rep Power: 28 ![]() |
probably you have 3 volumes that have nothing in common.
Are they connected properly using an interface? Better share a screendump of CFX- Pre so we can get a better picture. |
Hey,
thanks for the answer. I am pretty sure that I have set the interfaces correctly. If I set up exactly the same with a rectangular pipe cross section, i.e. a flow in the positive x-direction at the bottom, the porous membrane above and a flow in the negative x-direction at the very top with a flow through the porous domain exclusively in the y-direction, I get a result. I have also tried it with a quarter of the tube, there too I have a flow through the porous membrane. Only when I simulate it with the whole tube do I get no flow through the membrane. I don't understand this at all and can't explain it to myself. I have set exactly the same for all three variants. |
Gert-Jan
probably the setup is not exactly the same.
If you don't share more details (screenshots, outputfiles, etc), we cannot help you. |
countercurrent flow, porous boundary, porous domain, porous flow |
Display Modes | |
conjugate heat transfer in porous domain, CFX | CFXer | CFX | 5 | July 29, 2020 06:47 |
