How to check the value of applied loads at keypoints ?
Old   December 11, 2009, 21:44
Default How to check the value of applied loads at keypoints ?
pathfinder_jj is on a distinguished road
Hi all,
I have several sets of result after solving my analysis, I could access different sets of result by picking set "n" result from: Utility Menu > General Postproc > Read Results> By Pick.
however, when I tried to check each applied loads for each set of the result from: Main Menu > List > Loads > Forces > On All Keypoints, it only shows the applied loads for the last set of result.
Is there anyway that I could check the values for other sets of the result ?
Thank you.
pathfinder_jj is offline   Reply With Quote
Old   January 5, 2010, 10:26
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
I am not sure about the detailed method, but I think this could be done through APDL to do a batch run, to get the wanted results of several files.
rikio is offline   Reply With Quote
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Grid independence check Mattis Voss FLUENT 1 November 23, 2005 10:30
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 13:04
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
