when meshing the model, occur a problem.
Old   May 27, 2010, 00:27
Red face when meshing the model, occur a problem.
steven.shi
jinfengshi is on a distinguished road
hello, all;
the Ansys which i used is the ANSYS 12, and when i do a modal case, and import the model and define the dimension of the model, and when i mesh or solve this case, occur the problem.
this error message: "AnsysWBU.exe has encountered a problem. A diagnostic file has been written: C:\User\shijin~1\Appdata\Local\Temp\AnsysWBDumpFil e.dmp".
http://home.simwe.com/attachment/201...9270543iaC.jpg
Any idea whats wrong would be helpful, thanks in advance.
And our computer's system is Windows Vista
jinfengshi is offline   Reply With Quote
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
Convergence problem with thermal phase change model under low velocity conditions pitisrisuk CFX 0 July 21, 2009 11:21
Problem in Herschel-Bulkely model emad FLUENT 0 May 20, 2009 14:20
Problem with meshing long, thin faces in CFX Martin CFX 3 January 8, 2009 20:51
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
