July 27, 2010, 08:37 |
CAD interface, parametrization
Arányi Patrícia
Rep Power: 15 |
Hy everyone!
I'm trying to use a cad interface (Inventor) for Workbench 12.1, but I can't resolve how to handle the geometry's parameters. I want to optimize, but I don't know how to publish parameters from Inventor. Can anyone help me a bit, please? Thanks a lot, Patrícia |
August 3, 2010, 05:40 |
Rep Power: 15 |
1. Do you have the license to import cad data in file type of inventor? It is an additional license you need for that.
2. In Workbench take a look at "View - Options - Geometry Import" There the option "Parameters" should be activated and in the text field (Filtering Prefixes and Suffixes) below you should find "DS". That means: Each dimension in Inventor that you want to use (so you can change it within Workbench) needs the prefix "DS" in the name of that dimension. Simply give every dimension you want to change the prefix "DS". (Of course, you can change the prefix as you want. Or deactivate the checkbox, but then you get a lot of dimensions available.) |
August 3, 2010, 07:12 |
#3 | |
Arányi Patrícia
Rep Power: 15 |
Hy! Actually I got the license for the cad interface, and it's working, so I can change parameters in inventor, but my problem is the following: If I want to optimise a parameter, than I have to "publish" it. It's working when I'm using the Design Modeller, but when I use a cad interface I can't do the same. Do U have any idea how to do that? Regards, Patrícia |
August 9, 2010, 02:40 |
Rep Power: 15 |
I only can repeat myself:
When you create new a dimension in DesignModeller in a sketch or via extrusion, then the name of this dimension automatically has a prefix "DS". Because of that prefix you can use it to optimize a parameter. If you want to do the same in inventor you have to change the name of all dimensions in your modell and add the prefix "DS" within Inventor. Or, as an alternative way: Go into workbench to "View - Options - Geometry Import" and deselect "Parameters" under "Filtering Prefixes and Suffixes". |
August 23, 2010, 08:42 |
Arányi Patrícia
Rep Power: 15 |
Thanks a lot for the information.
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
CAD Interface problem | sweenam | Phoenics | 0 | November 9, 2002 06:08 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
