Home > Forums > Software User Forums > ANSYS
Heat transfer in circular tube with constant wall heat flux
Old   August 30, 2010, 20:30
Default Heat transfer in circular tube with constant wall heat flux
على رضوان
ali radwan is on a distinguished road
THANKS FOR ALL ,
I AM DEMENSTERATOR in mechanical power engineering Dept.
i am doing my master in heat transfser in circular tube fitted with wire coil insert . and i am a beginner in using fluent6.3.26.
i need the steps that i can follow to know how i can i dentify the boundery conditions of the problem, first with plane tube only.
the mesh was established in 2D axisymetric .
i have aproblem in the results of temperature distribution and local nusselt number ie.energy equation
ali radwan is offline   Reply With Quote
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 12:01
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 07:01
CFX - wall heat flux divarano CFX 2 December 4, 2006 16:14
