How to measure total Heat Power
Old   October 5, 2010, 01:41
Default How to measure total Heat Power
Cuong
myyahaha is on a distinguished road
Hi every body .
I'm learning to use Ansys ICepak to solve Heat problem . How ever I don't know to measure or get information about the most important thing in Ansys Icepak_ Heat power.
I'm searching some datasheets about : transistor, capacity and fan. However i don't know how to see the heat power because i'm ameatur . CAn you help me?
Thanks you very much.
Here is an example of a transistor's datasheet that i attached.
myyahaha is offline   Reply With Quote
Old   October 6, 2010, 10:13
Cuong
Can anyone help me please?
Old   October 26, 2010, 10:30
Melvin.
bighead is on a distinguished road
Usually, objects such as transistors are not modeled in ICEPAK. What you could do is to either modeled it as a planar (2d) or volumetric (3d) heat source. For most packages, such as BGA where the heating is usually a very thin layer, a 2D source is a gd simplification. For others where the temperature gradient in the block is important, den assigning a power to a block with thermal conductivity is good enough. However, if that is not important but you wanna retain the geometric characteristics of the block (for flow analysis), then you can use a 3D source.
After solving, you may wanna check how much of the heat flow goes to each of the 6 sides. So you can go to report summary and choose the object and indicate its high/low side. If all 6 sides are needed, than you can unchecked the combined values.
For fans/opening, you can do the same as well.
maybe you can describe in more details what you wanna model, and I can help you further.
bighead is offline   Reply With Quote
Old   October 27, 2010, 12:31
Cuong
Hi Bighead. I appriciate that you answer my question. However I think you maybe misunderstand. I already know how to model an Ansys Model but my question is "how to get information about the heat source?" . How to measure total heat power of an object by someway such as datasheets.. to fill information in Ansys model.
Can you help me please?
If you don't mind we can contact by email. Myemail is "clbhtsvnguyenmanhcuong@gmail.com".
Thank you very much. Have a nice day.
Old   October 28, 2010, 10:50
chaos_zzy is on a distinguished road
The real power loss (heat) normally need Electronics Engineer to calculate for you. if you konw the real working model of component, you also can calculated by yourself, such as switch frequency, currrent, voltage. Google it there are many formula telling you how to do it for different types of component. Or you can measure it when component working.
chaos_zzy is offline   Reply With Quote
Old   October 30, 2010, 06:14
Cuong
OK. thank for your help. I think i must ask my tutor. ^^
Old   November 16, 2010, 06:43
Melvin.
Sorry for my misunderstanding.
For most packages, there is usually a thermal design power (TDP) for steady state calculation. For transistors, its usually related to the current at the gates (Joule heating). These can be used as a starting point till you get more info from measurements. There are plenty of work done at the device level in thermal modeling. I think your answer can be found in the publications there.
Old   November 16, 2010, 23:43
Cuong
Thanks. However my tutor said that it wasn't a problem because i am engineer and i can allow how many total power i want.
Old   November 17, 2010, 08:47
However, in many cases, your enemy Electronic Engineer always want give you more heat.
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 07:01
Inconsistent Total Heat Transfer Rate Ken Adams FLUENT 0 July 24, 2007 11:04
Help! Total heat transfer rate doesn´t sum to zero Thomas FLUENT 0 April 6, 2005 02:55
Total heat through a wall massimo Siemens 0 December 22, 2002 12:25
