Home > Forums > Software User Forums > ANSYS
Running Ansys in BAtch Mode
Old   November 5, 2010, 12:27
Default Running Ansys in BAtch Mode
David S
kuleuvenstudent is on a distinguished road
Hello there,
We are two Engineering Students from the K.U.Leuven university and we're having some problems running ANSYS in batch mode.
Actually it's not really a fluidum-mechanical problem, It's about a dynamic analysis of a bridge....
We made a Ansys log file and when we paste this into the Ansys command line, the following ansys code let's us write the eigenfrequenties and the modal shapes to .dat -files. This works OK!
*DO,mode,1,10
SET,1,mode
*GET,Frequenties(mode),ACTIVE,,SET,FREQ
*CFOPEN,Frequenties%case%,'dat',.\output
*VWRITE,Frequenties(1)
(E16.100)
*CFCLOSE
*DO,enum,1,126
*GET,NodeData(enum,3),NODE,NodeData(enum,2),U,Y
*CFOPEN,'NodeData%case%_%mode%','dat',.\output
*VWRITE,NodeData(1,1),NodeData(1,2),NodeData(1,3), NodeData(1,4),NodeData(1,5)
(6E16.6)
*CFCLOSE
*ENDDO
*ENDDO
But we need to run Ansys in batch mode using MatLab.
The problem we have is that when running batch mode, ansys only writes the Nodedata files but not the Frequencies.... While it does both when not in batch mode...
This is how we try to start ansys:
cd C:/THESIS/Ansys
dos('del Orthotrope_Plaat.out file.* .\Output\*.dat');
dos('"C:/Program Files/ANSYS Inc/v120/ansys/bin/intel/ansys120" -b nolist -p ANFL -i Orthotrope_Plaat.inp -o Orthotrope_Plaat.out');
cd C:/THESIS/Matlab
Does Anyone have an idea of what's going wrong?
Kind regards,
David and Steven
kuleuvenstudent is offline   Reply With Quote
Old   October 18, 2017, 12:11
amacedo is on a distinguished road
Hi!
Have you found the problem? I am having the same problem and trying to solve it for a month. I can't find a solution for this anywhere. I've tried Ansys 13, 14, 17 and even reinstalled the one I have been using, 17.2 student. There is for sure something one must (or mustn't) do in the log file to run it in batch mode, but incredibly no one says what...
Thank you for your attention, regards
AMacedo
amacedo is offline   Reply With Quote
ansys batch matlab
Running macros in parallel in batch mode nomad STAR-CCM+ 13 February 22, 2013 08:30
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 07:50
A Loop problem when running UDF in the batch mode Jun Geng FLUENT 3 July 16, 2008 08:34
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 16:44
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 06:49
