ICEM: Thin Wall problem
Old   June 15, 2011, 13:39
Default ICEM: Thin Wall problem
just-right is on a distinguished road
I am meshing a wing like shape in close proximity to the ground. The geometry is 2 mm thick with an endplate on the side.
I am having problems with patch dependent meshing in relation to the points and the edges. Some nodes do not obay the surface, edges or nodes and actually penetrate the opposite surface.
I am currently using the following approach:
- Import geometry
- Name surfaces
- Keep curves and points
- Set global mesh sizes and enable curvature/proximity
- Change edge criterion
The mesh is full of errors because of these overlapping surface nodes. Could somebody recommend how to approach this problem with the exception of just creating 2 mm element all over the geometry?
just-right is offline   Reply With Quote
Old   June 16, 2011, 12:33
I have seperated the large surfaces and the small surfaces. There seems great sensitivity to the edge criterion. However, even though the curves that define the edges as well as the points are still there no consistency in the meshing process is present.
I have enclosed two pictures that should represent some of the problems I am having
The surface on the right is the symmetry plane it can be seen that it interchanges with the other surfaces.
The surface mesh is so deformed that it penetrates the other surface.
Old   June 17, 2011, 07:29
I have been using the "define thin cuts" approach with improvements. It resolves the small areas a lot better, however, I still encounter various difficulties. Primarily the area where the small faces and the larger faces of the diffuser meet the edge is maintained. Near the edge where the horizontal and vertical face of the diffuser meet it is not maintaind:
This problem occurs in the same region every time and it leads me to believe it is a function of the algorithm.
The current settings also don't obay the red lines between the symmetry plane and the actual geometry. Sometimes triangular faces of the symmetry plane collaps to the geometry in question and vice versa. It also regularly create piramid shapes by not connecting nodes to the curve:
I would imagine there is a solution to this problem. I have tried edge criterion but in combination with the thin cuts it results in a lot of holes in the mesh.
Old   August 4, 2011, 07:46
Zhang Yang
swiss_zhang is on a distinguished road
first thing to check is the quality of your geometry.
Does any line exsist between 2 adjacet surfaces?. If not, the problem you shown will occur.
swiss_zhang is offline   Reply With Quote
Old   August 6, 2011, 20:35
Yeah lines exist between the adjacent surfaces.
A good way to approach the problem is to use thin cuts and the ignore wall thickness option. Also I found slightly decreasing the edge criteria to further help with node allignment. The combination of all of this resulted in a good quality mesh for CFD analysis.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Deforming wall problem alxasli FLUENT 3 January 10, 2011 06:22
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
