what's d easiest way fr meshing Inlet Distortion screen geometry fr axial compressor? |
August 28, 2011, 21:22 |
Arun raj.S
Rep Power: 14 |
I have attached the sample geometry ...plz go through that and tell me some way for meshing this ....Your help will be highlly appreciated |
September 5, 2011, 14:07 |
Joshua Counsil
Rep Power: 17 |
It's a structured mesh, so use ICEM since the CFX Mesh program can only do unstructured meshes. Here's an ICEM tutorial for airfoils - the premise is the same: http://www.youtube.com/watch?v=tYrbS...21FB62D08CE10C
September 5, 2011, 14:17 |
Arun raj.S
Rep Power: 14 |
Hi Josh,
R u suggesting me to use structured grid ?....I am using unstructured Tetra volume mesh option in ICEM CFD for meshing this geometry...But for this I m getting floating point overflow error always..I don't know what to do now ...Please go through this once and give some idea... I have created the mesh for 90 degree distortion screen through Icem cfd and I have imported that in Ansys cfx....Earlier it has shown i m having isolated volumes ..But i m sure there are no isolated volumes ..So i have set the expert parameter to uncheck the isolated volumes ... After that it has shown that integer and real memory are low..so i have increased the stack memory size..Now finally it is showing "floating point overflow error "...( ONly 10 iterations are going after that solver gets stopped) type::steady state simulation Inlet boundary condition :: Static pressure Static Pressure=101325 pa Outlet boundary condition:: mass flow rate mass flow rate= 2 kg/s Remaining faces of the domains :: I have considered it as opening Opening boundary condition values:: opening Relative pressure = 1010325 pa opening Temperature :: 300k FOR SCREEN :: I HAVE CONSIDERED IT AS A WALL For the screen which i have kept inside the center part of the domain, i HAVE CONSIDERED THE SCREEN AS A WALL Turbulence model:: Shear transport(SST) Heat transfer model:: Total energy Solver settings:: Advection scheme:: High resolution Auto time scale:: conservative:: Time scale=0.75 I am not understanding whether i m doing any mistake in Boundary conditions..So plz help me in sorting this problem I m attaching a picture of model for reference... Your help will be highly appreciated |
Display Modes | |
Rotor 67 full compressor geometry | jf | Main CFD Forum | 3 | January 28, 2024 05:14 |
IGES/IGS format geometry file for icem meshing | littlelz | Main CFD Forum | 0 | May 27, 2008 18:24 |
Meshing Film cooling geometry | Janendra Telisinghe | CFX | 1 | January 31, 2006 06:16 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
