March 28, 2011, 03:07 |
Separate surfaces in DesignModeller 12
Rep Power: 15 |
I created 2 squares next to each other with one side in common.
I extruded them one by one, to the same height. Is it possible for me to specify such that they do not merge and share common surfaces? I want my block to have 10 unique selectable sides so I can insert different boundary conditions later. |
August 4, 2011, 07:55 |
Zhang Yang
Rep Power: 15 |
Try to Imprint Surface Function:
1: create a line 2 Extrude this line with Imprint Surface and this line will cut your box or block in different part you want |
September 19, 2011, 20:51 |
ben, I'm going to experiment with imprint today, but the trick I just worked out yesterday is to freeze the first body before allowing the 2nd to contact it - and that includes extruding a 2nd body to or from it.
[snappyHexMesh] snappyHexMesh not refining surfaces | Hydro1004 | OpenFOAM Meshing & Mesh Conversion | 3 | August 29, 2012 11:56 |
Exporting surfaces inside the control volume (interior) | bigmoneylou | ANSYS Meshing & Geometry | 1 | January 8, 2011 16:16 |
separating top surfaces after extruding the 2D mesh | Mario-CFD | ANSYS Meshing & Geometry | 3 | January 8, 2011 15:26 |
Faceted surfaces in ICEM | Chriss | Main CFD Forum | 1 | May 6, 2008 15:18 |
Surfaces | Mark | FLUENT | 2 | February 9, 2004 10:41 |
