Solver run time & # processors in post
Old   February 3, 2012, 10:15
Default Solver run time & # processors in post
anonymous
Doginal is on a distinguished road
Hi all
This may be either very simple or not possible. I'm trying to figure out how long a simulation took to finish as well as how many cores it was using to solve the case in CFX-post. All i have is the results file.
I started to try using a remote server to run some cases and i've been running into some issues so i want to check to make sure things are running as they should with some test cases before submitting bigger jobs. Any help would be greatly appreciated.
Thank You,
DM
Doginal is offline   Reply With Quote
If OpenFOAM can run different solver in different domain in the same time ? panda60 OpenFOAM Running, Solving & CFD 4 May 15, 2014 10:07
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
