help need for my project: design n simulation of ic engine |
February 9, 2012, 20:05 |
sid
hi all,
i m student of BE mech. engg. i m working on project of design n simulation of ic engine. can any 1 recommend me which s/w will be best to work on???? i would be thankful if any can briefly help me in approaching this project... thank you with regards sid |
February 10, 2012, 09:01 |
One of the most simple and most used ones is Fluent and Gambit or the latest version called Ansys workbench.
make sure what you are analyzing.. Like combustion pattern, Formation of soot/Nox, Effect of different fuels, effect of diff injection/spark timings etc. |
February 10, 2012, 11:49 |
sid
thank you very much for the info... is it possible to work only on ANSYS 13???
February 10, 2012, 12:01 |
February 27, 2012, 08:21 |
sid
if i m using ansys 14 how do i start ????
February 27, 2012, 22:03 |
sheth roh
As you said you're working on BE project, I assume that you have very limited time to complete.
IC engine simulation is not just one small things actually many small analysis are involved, and learning each of them in short time might be difficult. It can mainly be classified in structural and fluid analysis, and there is FSI (fluid structure interaction), in FSI you study effect of fluid on structure or vice-versa. If you're from mechanical stream you should opt some structural analysis and if you would like to do fluid analysis (using CFD), learn from some research papers/project first and then use CFX or Fluent tutorials. Although cfx doesn't have particular ic engine tutorial, it has some other relevant tutorials. |
Composite Engine Valve Project | cortez505 | FLUENT | 1 | November 18, 2009 04:02 |
IC Engine Flow simulation | Apurv | Main CFD Forum | 2 | February 8, 2000 00:12 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
Engine simulation (seeking help with method to use) | Geoff Rathbun | Main CFD Forum | 4 | April 13, 1999 14:19 |
Question concerning about the flow simulation of a fan in an engine room. | ghlee | Main CFD Forum | 3 | October 21, 1998 07:05 |
