GPU acceleration - nvidia quadro K2200
Old   May 16, 2016, 03:57
Question GPU acceleration - nvidia quadro K2200
crevoise is on a distinguished road
Hello
I have a workstation with a nvidia quadro K2200 installed.
I am trying to run a thermal - statistical analysis.
When using 8 CPU, everything is OK, but still slow.
When activating the GPU acceleration, things start really fast and then stop with the following message error:
"an error occured inside the solver module: general error"
Does anyone knows why this problem and how to solve this issue?
Thanks a lot
crevoise is offline   Reply With Quote
Old   May 18, 2016, 21:07
James Wright
u2berggeist is on a distinguished road
My experience with trying to run CFD on GPU's is very minimal, but you might want to check and see if your GPU has the memory necessary to hold the simulation on it. That was the problem I quickly ran into, and then subsequently gave up on.
What solver are you using? Try and find an output file in the Workbench directory (sounds like you're launching this through workbench based on the error). Workbench error messages are generally pretty worthless. I know CFX .out files give pretty decent information about what the actual problem is normally.
u2berggeist is offline   Reply With Quote
Old   May 20, 2016, 14:27
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you may check that whether it is a problem with GPU or not by running longer on cpu. If you still same error, then you have somewhere else...
Far is offline   Reply With Quote
apdl, gpu, nvidia
GPU acceleration on ANSYS Fluent 14.5 Daveo643 FLUENT 20 April 28, 2018 13:50
Nvidia Quadro K4200 useless for Ansys acasas Hardware 4 January 14, 2015 08:47
What solver would benefit from GPU acceleration? Lukasz OpenFOAM Running, Solving & CFD 0 October 15, 2013 15:19
NVIDIA Tesla GPU ztdep Hardware 0 December 7, 2010 21:00
New Nvidia gpu aimed at gpgpu bmeagle OpenFOAM 0 November 9, 2006 09:41
