Home > Forums > Software User Forums > ANSYS
mesh - file from stand alone project
Old   April 16, 2012, 13:29
Default mesh - file from stand alone project
Stephan Langenberg
Jim87 is on a distinguished road
Hallo,
I've got a .cas- and a .dat - file. In order to check the quality of the mesh I want to create a meshfile out of this "stand - alone - project" (Fluent Analysis System in the toolbox)
Does anyone know how to get the mesh (.msh) from an existing Case or Data?
greetings,
Jim
Jim87 is offline   Reply With Quote
Old   April 16, 2012, 13:46
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i never had the occasion to try but in Fluent if you click on file>write>boundary mesh, it will generate a .msh file for you. May be that's what you want let me know if it works
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 16, 2012, 17:48
Stephan Langenberg
That was the first thing I did
I tried it and noticed that the boundary mesh and the "normal mesh" are nt the same. If I have a normal mesh (for example in the component setting) I can link it to the finite Element Modeler and check the settings. (skewness, aspect ratio etc.)
I guess the finite Element Modeler should be linked to the "stand - alone -project" similar to the coponent construction, but I don't get it.
greetings,
Jim
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
