Home > Forums > Software User Forums > Autodesk Simulation CFD
The Parabolic Phenomena of a Spinning Fluid
Old   August 26, 2012, 05:19
Default The Parabolic Phenomena of a Spinning Fluid
Bruce
whygee is on a distinguished road
Hi all,
I'm trying to simulate the parabolic phenomena of a spinning fluid (the phenomena is described in rotate-body.jpg)
I'm using Autodesk Simulation CFD and trying to simulate the simplest configuration as possible.
the rotating part is a cylinder with inner cone (pic1)
i created another part, which is the initial water level inside the cone (also in pic1).
I'm having difficulties defining the rotating part and water area.
could anybody help me defining any solution the solver can handle? i would really want to see the phenomena as demonstrated in "rotate-body.jpg"
Thanks in advance,
nyg
whygee is offline   Reply With Quote
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
[ANSYS Meshing] How to include an internal surface in fluid vol jwillie2000 ANSYS Meshing & Geometry 0 May 4, 2012 11:10
Questions of fluid pairs fjalil CFX 1 June 10, 2009 17:36
Fluid pairs fjalil Main CFD Forum 0 June 10, 2009 13:47
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
