August 27, 2012, 01:56 |
Compressible flow Simulation in CFDesign
Trying to solve a high subsonic compressible flow through a butterfly valve.
Having lot of issues with convergence. Typical problems like 1. High unrealistic velocities in enhancement layers. 2. Unrealistic high pressures. 3. High velocity at outlet. settings used are : Inlet: velocity and static pressure Outlet: unknown Turbulence Model - ke Please advise if any settings to be enabled or the process to achieve good convergence for compressible flows in CFDesign Thanks |
September 9, 2012, 23:00 |
Definitely check out the suggested setups for internal compressible flow in the Simulation CFD Wikihelp:
http://wikihelp.autodesk.com/Simulat...62-Internal762 The most common setup approach for these problems is Total Pressure >0 at inlet and Static Pressure = 0 at the outlet so you might want to start there. If you need to use the velocity and pressure at the inlet with unknown at the outlet like you described, make sure the pressure is a total pressure boundary condition. Beyond that, mesh refinement will probably be helpful. You might also try some solver relaxation in the Solution Controls dialog. You can log a support case here if needed: http://subscription.autodesk.com/sp/...74&id=11607975 |
compressible flow, subsonic flow |
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? | alpharays | Main CFD Forum | 0 | April 19, 2012 03:13 |
how to set BC for compressible flow target mass flow rate | foolboy007 | FLUENT | 1 | April 4, 2012 03:24 |
CFDesign V11 -- Reverse flow at outlet | maruthiv | Autodesk Simulation CFD | 1 | June 17, 2011 09:38 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 17:23 |
