Home > Forums > Software User Forums > Autodesk Simulation CFD
Saving bulk results on a plane as a function of time in transient analysis
Old   September 26, 2013, 15:40
Default Saving bulk results on a plane as a function of time in transient analysis
CFD
cfd1980 is on a distinguished road
Hi everyone,
I am running a transient analysis and am trying to get a delta P between two planes (one near inlet and one near outlet). Is there a way to automatically save the Pressure (or any other variable for that matter) automatically at every saved time step. I have seen the Bulk tool which will give you the average values over the plane at individual time steps but there is no way of automatically saving these values as a function of time. You have to save a *.csv file individually at each time step manually.
Also the Decision center seems to be for seeing the variation between the different scenarios not for variation with time in an individual scenario.
thanks in advance,
cfd1980 is offline   Reply With Quote
Old   October 22, 2013, 14:25
Apolo
ApoloV is on a distinguished road
One trick to getting the data (assuming you have intermediate save results):
Set your plane where you want it.
Right-click and go to the animation pane
Animate the results through your save intervals
While animating go to the Bulk Calculator and select the quantities you want, you will be able to save the bulk results for that plane across all saved intervals into 1 csv file
Repeat for any other plane
ApoloV is offline   Reply With Quote
Old   June 23, 2015, 04:59
ecomo is on a distinguished road
Hi everyone,
I've got exactly the same problem. After searching the internet a little I found this cool forum and even a hint on the Autodesk website (at the bottom) giving the same advice this thread.
Nevertheless it doesn't work- and I'm starting to doubt myself. Propably it's one of these stupid faults..
So I would be very grateful for any help!
I'm using Autodesk CFD 2016. I carry out the following steps:
  1. Running a transient analysis
  2. Placing a plane in the model
  3. Open the animation pane
  4. Clicking animate
  5. After the "animate"-button turns grey, clicking the "play"-button in the animation pane
  6. While the animation is played, right clicking on the plane placed in 2.
  7. Clicking "Buld data"
  8. Choosing the desired data (in my case mass flow)
  9. Clicking "save" in the bulk data dialog
What I get is a CSV-file with only a single datapoint from the time step where i pressed "save". Instead of one CSV-file with all the data of all time steps.
I'm grateful for any help after I wasted so much time on it.
ecomo is offline   Reply With Quote
Old   June 23, 2015, 09:44
Ok, I found it out- the 2016 Version sucks!
With Autodesk CFD 2015 its working perfectly fine!
transient final time step results hmasenger CFX 5 September 17, 2013 11:24
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
