March 19, 2016, 12:18 |
Heat transfer in a pipe flow
Prabhu Prakash
Rep Power: 10 |
Dear all,
kindly help me with the following problem. Pipe ID = 300 mm Pipe OD = 320 mm Pipe Length = 15 m Fluid = steam Pipe material AISI 1330 (density = 7870 Kg/m^3 | Sp. heat = 472 J/Kg K | Th. conductivity = 51.9 W/m K) Available Boundary Conditions at Inlet are: Mass flow = 90 tons/hr Velocity = 17m/s Pressure = 64 Bar Temperature = 480 Celsius Assumed film co-efficient = 14.5 W/m^2 K Tool used: Autodesk CF Design 2013 & 2015 I have solved the problem, but the outputs are not as expected. What kind of settings to be followed throughout. Can you kindly help me in solving the problem. |
cfd analysis, heat transfer, pipe flow |
Display Modes | |
Reverse Flow In NanoFluid Based Double Pipe Counter Flow Heat Exchanger | nabidinhomessi | FLUENT | 0 | November 15, 2015 09:33 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[ANSYS Meshing] heat transfer through a pipe | cfdjunkie | ANSYS Meshing & Geometry | 3 | September 18, 2012 21:53 |
Conjugate heat transfer in reacting flow | ali_1364reza | OpenFOAM | 1 | May 30, 2012 14:15 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
