water turbine/mill/wheel, measure torque/momentum
Hello, I have to simulate the passage of water through a turbine and measure the torque/momentum generated. The geometry of the turbine must be imported from the autocad.
Is it possible to do this in the cfd program of autodesk? Thank you very much for the help |
Yes, this is possible.
I don't really like to suggest it on here but I would ask over on the Autodesk forums once you get started, makes more sense ;) |
