Home > Forums > Software User Forums > Autodesk Simulation CFD
Simluate smoke indoor (Smoke visibility​).
Old   November 27, 2012, 03:31
Default Simluate smoke indoor (Smoke visibility​).
Timmy Tang
z3351922 is on a distinguished road
hi~
I try to do the smoke visbility on Autodesk CFD simulatio, but i can't generate the smoke in CFD
i follow the GuideLine, but it is still not success.
Can anyone help me here ???
I created a house with two holes. One is on the side, One is on the ceiling.
In the middle of the house there is a box where the fire generated.
material
Volume inside the the house is air. I set it to be variable.
The wall of the house is brick. The box in the middle is made by hardwood.
Boundary Condition
Box: Scale = 1, Heat Generation = 2000W
Air: Film Coefficient = 5 W/m2/K, Ref. Temp. = 19 Degree
Hole on Ceiling: Volumetic Flow Rate = 50 L/s,
Hole on Side : Pressure = 0Pa , Temperature = 20 Degree.
Solve:
Set Smoke Visibility on
Heat Transfer on
Specific Extinction Coefficient = 21000
The sign visibility constant characterizes = 3
combustion particulate yield = 0.08
Diffusion Cosfficient = 16 mm^2/s
Solution :
i set the output quantity is Scalar
However, i cannot see the smoke in the CFD.
Can Anyone help me
I want to create the view like the one in the Guideline. Smoke visibility
z3351922 is offline   Reply With Quote
Old   July 2, 2016, 15:59
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
How can I simulate the fire of diesel for a smoke simulation in fluent?
Ahmed Saeed Mansour is offline   Reply With Quote
Old   October 16, 2018, 09:42
Nazim
shahid nadeem is on a distinguished road
HI did you got the method
Thanks
shahid nadeem is offline   Reply With Quote
Old   October 19, 2018, 18:27
Have a nice time!
Hello, I got a UDF from a video but I did not try it because the project was done by FDS. I can send the snapshot to you
Thanks
Old   October 21, 2018, 04:06
Nazim
Please, it will be great
Old   October 21, 2018, 14:47
Have a nice time!
Here you go Thanks
Car park ventilation and impulse fans guillaume Phoenics 9 October 27, 2015 05:57
Questions about smoke modeling using CFX rafiktharwat CFX 0 March 14, 2011 11:38
smoke (fire simulation) matt Siemens 0 January 5, 2007 04:48
smoke (fire simulation) matt Fidelity CFD 0 January 5, 2007 04:47
smoke & screen Marko Main CFD Forum 12 May 15, 2000 11:56
