Home > Forums > Software User Forums > Autodesk Simulation CFD
Mixing efficient analysis within a tube with 4 inlets ?
Old   May 5, 2025, 10:24
Default Mixing efficient analysis within a tube with 4 inlets ?
Tanguy
tanguy.vr@manetco.be is on a distinguished road
Dear all,
I am happy to join the Forum. We focus on simulations of liquids within tubes. We have a project where we need to mix 4 different liquids from 4 different inlet.
We are often doing this type of simulation with 2 inlets. In that cas, we use the passive scalar to observe the mixing efficiency which works fine.
With 4 inlets, this method doesn't work --> does someone have already work on a similar project ? What could be the alternative solutions to visualize the mixing efficiency of these 4 liquids which are homogeneous.
Thanks !
Tanguy
tanguy.vr@manetco.be is offline   Reply With Quote
[OpenFOAM] Tube filter in Paraview werweisswas ParaView 0 December 10, 2012 07:18
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
Concentric Tube Heat Exchanger Analysis Abhishek CFX 3 November 8, 2011 06:45
[blockMesh] Most efficient way of adding a number of small (gas) inlets, compared to cell size kjetil OpenFOAM Meshing & Mesh Conversion 2 November 11, 2009 06:35
Floworks: Mixing and thermal analysis of two gases Jay Nelson Main CFD Forum 0 June 14, 2005 19:29
