June 17, 2011, 09:36 |
CFDesign V11 -- Reverse flow at outlet
Maruthi Chaluvadi
I am trying to run an analysis on a flow path of Solenoid valve in CFDesign.. The boundary conditions are : Inlet (2 intlets): 185 KPa and 80C (temp) Outlet (4 outlets) :0Kpa (2 circular and 2 ellitical gemoetry) Now after running the analysis, at the outlet if i see the vectors, they show flow out for half the outlet and flow in the backward direction for the other half. Is this beacuse of circulation, vorticity? Do they effect ?? How can i get rid of this flow vectors showing back flow. I tried extending the outlet so the flow will be developed. But that is effecting my flow rate at outlet surface which is what i am trying to calculate. Please give your insight!! Thank you. Maruthi |
June 17, 2011, 09:38 |
Have you got a pic?
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Outlet boundary conditions for unsteady flow | Bjorn B | Main CFD Forum | 3 | January 11, 2006 05:42 |
Reverse flow in the VOF model | yan | FLUENT | 1 | May 26, 2005 09:14 |
reverse flow | P.R.Naren | FLUENT | 5 | May 19, 2005 01:15 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 10:44 |
