Home > Forums > Software User Forums > AVL FIRE
Change boundary condition in AVL FIRE
Old   January 18, 2012, 11:19
Default Change boundary condition in AVL FIRE
neu
neu is on a distinguished road
Hi Guys,
I injected fuel from a small hole into a constant volume chamber in AVL FIRE v2008. The boundary condition for inlet is total pressure. After some millisecond I want to stop injection without stopping the program running. I think that I must change boundary condition from inlet to wall but I am not confident how can I do it?
Did anyone encounter with this problem hitherto?
Thanks,
neu
neu is offline   Reply With Quote
Old   January 18, 2012, 13:02
Rahul
Rahul_W is on a distinguished road
Hi
I dont know about AVL FIRE v2008 software but this may help you
you can simulate your problem with inlet boundary condition for required time step and then make inlet boundary condition to wall and initialize the problem with previous result and run again.
Rahul_W is offline   Reply With Quote
Old   January 19, 2012, 11:38
doki is on a distinguished road
I am not sure if I get the problem correctly, but you SHOULD set a "physical" BC to get physical results.
I mean, you should think of what is happening in reality. as the pressure conditions are not "imposed" suddenly in the real case, you should use time-variable BCs in which the inlet pressure decreases from the maximum to ..... in a couple of time steps; e.g.:
1 100000
2 70000
3 50000
4 20000
5 ....
hope that helps
doki is offline   Reply With Quote
Old   January 19, 2012, 12:07
neu
Hi doki,
What is the final pressure with passing the time?
As you know when injector is closed the inlet must be changed to wall not its pressure decreases. Because with decreasing the pressure the flow may exit from inlet if inlet pressure be smaller than inside pressure. Is it correct?
Best,
Use DEFINE_ADJUST change boundary condition liurengtong123 Fluent UDF and Scheme Programming 29 January 14, 2024 00:56
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
change boundary condition on the fly liu OpenFOAM Running, Solving & CFD 0 June 29, 2010 14:30
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 06:45
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
