September 20, 2012, 06:25 |
"word too long" error for MPI calculation
Daniele
hello everybody
i use AVL Fire 2011 on Ubuntu 12 and when I try to start a simulation using all 4 of the CPUs (default settings) I get an error from the shell where Fire is running. After typing my password (it is needed to connect to myaccount@127.0.1.1) i can read: fire_cmd@myaccount: Word too long. Word too long. Word too long. MPI Application rank 0 exited before MPI_Init() with status 1 mpirun: broken pipe Has anybody ever got this problem? Thank you for your help |
January 16, 2013, 11:17 |
problem solved
Daniele
I've solved the problem using the 64-bit version of Fire
the installation hasn't been easy, but now it works also with more than 1 processor. |
avl, fire, mpi, mpi errors, word too long |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 09:37 |
Questions on Boundary Layer Spring Method for 3D Calculation | didiean | FLUENT | 15 | December 18, 2014 21:09 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 08:19 |
