Home > Forums > Software User Forums > AVL FIRE
injector position error
Old   May 13, 2014, 04:24
Default injector position error
shahrbanoo
shahrbanoo is on a distinguished road
Hi dears
I'm modeling SIDI engine.when after I run the case, it stops in the begining of spray start.and I face this error i fla file:
Testing proper position of injector:
%fire-I-cysetup,
%fire-I-cysetup, Bores could not be located inside domain.
Check position of injector !!!
%fire-I-cysetup, Test of injector position failed !!!
Bore center at gridline or outside grid !!!
%fire-I-cysetup, Calculation continues.
%fire-F-cyintro, Execution terminated! Bore seems partly outside domain.
Tried more than 1000 times to locate parcel in bore.
but I've checked and my injection place is in the computational domain. Actually my injection place is the same as injection direction in geometry data of Nozzle.
Could u please help me? what is the problem?
thanks
shahrbanoo is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
