April 8, 2015, 04:51 |
Launching a FIRE simulation
Jorge Muņoz
Rep Power: 16 |
Hi everybody,
I guess I am the most stupid all over the forum, as I cannot even start FIRE in Linux. I mesh file and the only thing I want to do is to open FIRE, import the mesh and create a new project so that I can start setting up the simulation. As far as I know, the syntax should be: .../fire_cmd -name=fire -solver_vers=v2013.2 -project_dir=path -project=projectname -case=casename -cfd_mesh=meshname -mpi -cpu=16 -hostlist=hostname1,8,mpi:hostname2,8,mpi However, there are some questions I have, as FIRE is not opened but message saying 'abnormally finished' is given: 1. project_dir= is this the path where we want to save the calculation folder and the project file? I guess it is. Does it need to also have the mesh file inside? 2. project= what is this if the simulation has not started yet nor a project has still saved?? Should I give a default name? I tried giving a dummy name (e.g. test00.fpr) but it says no project file was found (obviously, the simulation did not start yet!) 3. case=again the same. Should I give a name in particular a priori? 4. hostname1 and hostname2 = the idea is to use two nodes of our closer (namely nodo10 and nodo11, each of which has 8 processors). The machine name is flu, so how should we call each node? I tried to import the mesh in my Windows machine, and I saved a project and a case, and I upload these files to my Linux machine, so now I have these files, but it is still an error (please, find attached a scan of the message). What should I do?? Any help is welcome, thanks in advance! /Jorge Last edited by L3munoz; April 8, 2015 at 04:58. Reason: The original picture was a .png but the website changed it to .jpg so quality was too low |
April 14, 2015, 05:58 |
Rep Power: 14 |
Hi Yes, prior to the above command, you should have a valid project file, Meshes folder, Calculation folder, and the Case folder with valid ssf in it.
May 20, 2016, 04:43 |
Zvonimir
Rep Power: 10 |
Ji l3Munoz,
problem is probably in -project=projectname.fpr --> you must include *.fpr extension. Also, for this -hostlist im not sure but try without and with this option. For sure -project must be -project=project_name.fpr BR Z |
Display Modes | |
AVL fire CI engine simulation neeed HELP ! | Mohsen khalafi | AVL FIRE | 1 | September 10, 2018 11:32 |
Simulation in MPI mode with AVL fire 2008 in windows 7 | superflame | AVL FIRE | 2 | June 30, 2013 21:25 |
smoke (fire simulation) | matt | Phoenics | 4 | October 23, 2007 02:40 |
smoke (fire simulation) | matt | Main CFD Forum | 0 | January 5, 2007 05:45 |
Temperature errors on fire simulation? | raymond | Siemens | 0 | January 10, 2002 21:32 |
